Old 12-17-2013, 04:08 PM   #1
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Default SBC Super Stock Roller Cams & Rear End Gears
3 - SBC Super Stock Roller Cams - all standard journal size.
- 1 New Bullett Cams - 306 /314 R4 (.420"in / .435"ex Lobe Lift) - $195
- 1 Used Comp Cams 4496 / 316-8 R8 (.420"in / .440ex Lobe Lift) - $150
- 1 Used Comp Cams 308-8 / 312-8 R4 (.440int / .440 exh Lobe Lift) - $150
All fairly close - work well with Carb or EFI sbc applications -
and use at least a 1.8 in and 1.6 ex Ratio Rocker (first and third cams can use up to a 1.9 rocker and all three can use up to a 1.65 exhaust rocker).
Also -
5.83 & 5.67 - 9" Ford M/W Lightened Richmond Pro Gears Sets
Little use - in great condition
Purchased through Mark Williams - w/ lightened ring gear.
$ 185 each + shipping.
Email or PM
aditocco@aol.com
Also - still have Quay 82-92 Camaro F-Body Idler Arm / Steering Damper / TRW Tie Rod Ends / Quay modified BBC Motor Mounts (just engine pieces) / all brand new - never used. - make offer
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
