Liked 294 Times in 93 Posts
I can make a 4 1/2 BS work. Prefer Weld Pro Stars and Aluma Stars, but will consider all.
Thanks RJ |
Liked 56 Times in 29 Posts
Would you consider nickel alloy hoop steel wheels, 19 lb. each? They were made by Marsh Racing.
RJ, give me a call. I think I got what you need. 256-810-6162
Jeff Strickland |
Liked 784 Times in 196 Posts
RJ, somethign doesn't seem right . . . 5x4 3/4 is a GM bolt pattern.
Its like the 2.200 rod journal in an FE.........its 2 tenths faster with the GM Bolt Pattern. But don't tell Larry Hill. Shhhh.....
Merry Christmas RJ |
Liked 325 Times in 50 Posts
I got lot's of 4.5 bc. I will look and see if there are any bow tie wheels. What are you doing with bow tie wheels. I worry about old guys like you.
Jeff Teuton 4022 STK |
Thanks all!
Got a pair of wheels from Jeff Strickland that I believe will work. Jeff T thanks for looking. See if you have some 15x3, 5x4 1/2 BP and 2.25 BS for the front. Thanks and Merry Christmas RJ |
I think I got some 15 x 4. I will look.
