Old 12-09-2013, 10:52 AM   #1
Lyn Smith
Liked 980 Times in 197 Posts
Default GM points to electronic distributor conversion
Im trying to copy a conversion i saw on the internet that converts a Gm points distributors to electronic(street applications) by using a chrysler reluctor,and pick up coil,and a GM 4 pin module mounted under the distributor.What coil could you use for this?Would a hi per accel coil for non HEI work? thanks
