Old 12-06-2013, 10:22 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Collector tether question
If your collectors bolt on.to the headers with tabs are you still required to use the tethers? Thanks
jaf2021 is offline   Reply With Quote
Old 12-06-2013, 10:27 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Collector tether question
Originally Posted by jaf2021 View Post
if your collectors bolt on.to the headers with tabs are you still required to use the tethers? Thanks
yes
voltdr is offline   Reply With Quote
Old 12-09-2013, 03:08 PM   #3
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
Only way you DO NOT need tethers is if you weld the collectors to the tubes. I believe the rule says you need at least a 1" stitch on at least 2 tubes but I could be off on that.
H.A.A.C. Racing is offline   Reply With Quote
Old 12-09-2013, 03:49 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
1/2" weld per tube......I just did mine and tig welded them a lot more than that.
They needed recoating anyway and I also added a weld bung for O2....
Now I need a big box to ship them in.....
Rich Biebel
S/C 1479
Stock 147R
