Old 11-08-2006, 11:28 PM   #1
Jeff Lee
Guest
Posts: n/a
Default AMC race clutch
Complete clutch / flywheel / pressure plate assembly. Custom drag race assembly by Advanced Clutches (see www.advancedclutches.com).
This is a custom ultra-light assembly. Total weight of all pieces approximately 24#'s.
Flywheel is scalloped looking design, looks kind of like a spider web. Custom heat shields. 10" sintered iron disk (18 spline Chrysler size). Adjustable base pressure. Pressure plate is aluminum ring and has optional windows installed in the cover assembly. Titanium nuts, bolts, studs and levers. Rebuilt by Advanced with new heat shields, disk, springs & ring gear. Advanced has agreed to replace the disk to your spline and include set-up (lever heights, counter-weights, etc.) to your requirements. This is the finest clutch assembly available and Advanced has said the new owner will be treated like the original owner; complete consulting service to obtain the very best ET possible for your vehicle. This is a bolt-in deal that will fit using the Lakewood 8 1/8" bellhousing and stock fork & throw-out bearing. This is a $2900 unit and a 90 day wait. This is a spare assembly for me and the one in the car works so well I see no need in a spare. I will sell this for $2400 to include shipping in the continental USA. It will arrive direct from Advanced Clutches to your door after they set it up to what is needed. Most users report gains of .10-.20 immediately over their McLeod Soft-Lok assembly, expect double if you are running typical mail order units. It's that good! (zero-balanced). If you need the flywheel register cut for the 401 4 5/8" O.D. flange, add $100.00.
PayPal accepted if you ad 3%.
Thanks,
Jeff Lee
NHRA 7494
SS/H '70 AMX
Realty Experts, Inc
602-418-9797
Arizona Real Estate Professional-for 14 years!
