Old 11-08-2006, 11:35 PM   #1
Jeff Lee
Guest
Posts: n/a
Default AMC V-8 Stock Eliminator cams
I have various AMC Stock Eliminator hydraulic cams for sale. All never used ( a few installed only to check clearances). Some had too much lift per NHRA rules and / or to much duration to clear the pistons. Approximately .450" lift as measured at the valve with 260 to 290 degrees duration at .050" lift. Both Lunatti and Comp Cams. I've moved to Super Stock so I have no use for these and I don't need candle holders! These are approximately $200 each new, will sell for $75.00 each.
PayPal accepted if you ad 3%.
Thanks,
Jeff Lee
NHRA 7494
SS/H '70 AMX
Realty Experts, Inc
602-418-9797
Arizona Real Estate Professional-for 14 years!
