Old 12-02-2013, 01:05 PM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default 9" Rear Questions
Apologies if this is in the wrong forum...
First off, some info on my car….1970 Mustang bracket car, 3400lbs., small block 351 Windsor, automatic leaving off a footbrake, Caltracs & 29.5x9” slicks. It runs 10.50’s with average 60’ times in the low 1.40’s with nice wheelstands.
So I am upgrading my 9” rear to 35 or possibly 40 spline axles and I need to buy a new larger bore case.
First question, is a Mark Williams Aluminum Thru-Bolt 9” center section a good idea? The rear end is braced and straight and I will be using a light weight steel spool and Pro Gears.
Concerned about deflection and longevity, mostly. And how much weight is really saved?
Stick with a nodular iron case?
Secondly, regarding 35 vs. 40 spline axles, obviously the price difference is significant, would 35’s be sufficient or are 40’s overkill for my application? I must say I like the peace of mind overkill can provide sometimes!
Are there any details I am overlooking or is this a straight swap into my housing? Housing ends, bearings, seals etc.?
Joe Grippo is offline   Reply With Quote
