Old 11-28-2013, 10:45 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Post Racepak question
Hey guys this is my first time running a stocker and a car with a racepak and i need to know if on a racepak graph after a run if the driveshaft graph shows a spike during/after the shift if that indicates tire spin and if you see spikes down track on the RPM graph after the 2,3 shift if that indicates a high speed miss.Thanks just doing a little after the race troubleshooting.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 11-28-2013, 11:16 PM   #2
Chad Rhodes
Default Re: Racepak question
Drive shaft spikes, or a jump followed by a plateau would be tire spin. Spikes or zig zags in the rpm can be several things; valve bounce, intake reversion, ignition issues, detonation, or a hole in the fuel cure to list a few.
Chad Rhodes 2113 I/SA
Old 11-29-2013, 09:54 AM   #3
Bill Grubbs
Liked 564 Times in 66 Posts
More than likely what you are seeing is the tire unwrapping/ wrapping up around the wheel (drive shaft).
Bill Grubbs is offline   Reply With Quote
Old 11-29-2013, 12:02 PM   #4
voltdr
Liked 100 Times in 51 Posts
Which Racepak system are you using? If it has the accelerometer, you can use it to look at spin/hook issues also.
voltdr is offline   Reply With Quote
