Liked 162 Times in 43 Posts
Perfect time to pick up some parts for that off-season engine build at a great price...
Lot 1: CP Pistons for 14 Degree Oldsmobile Big Chief Heads 8 New Pistons Bore Size: 4.600", Compression Height: 1.120" Top Ring: 0.043, 2nd Ring: 0.043, Oil Ring: 3 mm Dome Height: 0.165", In Relief: -0.240", Ex Relief: -0.010 Pin Diameter: 0.990", Pin Length: 2.930" $500 OBO plus shipping [IMG] ![]() Lot 2: CP Pistons for Big Block Chevy 10 New Pistons Bore Size: 4.608", Compression Height: 1.150" Top Ring: 0.043, 2nd Ring: 1/16, Oil Ring: 3/16 Flat Top with Intake Relief Pocket Pin Diameter: 0.990", Pin Length: N/A Will Need Pin Buttons Made for Desired Pin Length $500 OBO plus shipping [IMG] ![]() Lot 3: CP Pistons for Big Chief Heads 10 New Pistons Bore Size: 4.600", Compression Height: 1.078" Top Ring: 0.043, 2nd Ring: 0.043, Oil Ring: 3 mm 17 cc Tapered Dish, In Relief: -0.245", Ex Relief: -0.050 Pin Diameter: 0.990", Pin Length: N/A Will Need Pin Buttons Made for Desired Pin Length $450 OBO plus shipping [IMG] ![]() Lot 4: CP Pistons for Small Block Chrysler 10 New Pistons Bore Size: 4.165", Compression Height: 1.312" Top Ring: 1/16, 2nd Ring: 1/16, Oil Ring: 3/16 Flat Top, In Relief: -0.280", Ex Relief: -0.230" Pin Diameter: 0.990", Pin Length: 2.750" $500 OBO plus shipping [IMG] ![]() Lot 5: Bill Miller Engineering Pistons for 427 (435 HP) Chevy Closed Chamber 9 New Pistons Bore Size: 4.310", Compression Height: 1.760" Top Ring: 0.031 Dykes, Oil Ring: 3/16 Dome Piston Pin Diameter: 0.990", Pin Length: 2.930" $400 OBO plus shipping [IMG] ![]() Lot 6: Bill Miller Engineering Pistons for 454 (425 HP) Chevy 10 New Pistons Bore Size: 4.310", Compression Height: 1.634" Top Ring: 0.031 Dykes, Oil Ring: 3/16 Dome Piston Pin Diameter: 0.990", Pin Length: 2.930" 0.125 wall pins included $425 OBO plus shipping [IMG] ![]() Lot 7: Venolia Pistons for 427 Chevy Open Chamber 4 New Pistons Bore Size: 4.310", Compression Height: 1.760" Top Ring: 0.031 Dykes, 2nd Ring: 0.043, Oil Ring: 3/16 Dome Piston Contoured to Fit Head Pin Diameter: 0.990", Pin Length: 2.930" $80 OBO plus shipping [IMG] ![]() Lot 8: Venolia Pistons for Big Block Chevy 8 Used Pistons with 2 New Spares Bore Size: 4.560", Compression Height: 1.365" Top Ring: 0.043 Dykes, 2nd Ring: 1/16, Oil Ring: 3/16 Dome Piston Pin Diameter: 0.990", Pin Length: 2.930" $300 OBO plus shipping [IMG] ![]() Lot 9: Venolia Pistons for Small Block Chevy (255HP 350) 8 Used Pistons Bore Size: 4.030" Top Ring: 5/64, 2nd Ring: 5/64, Oil Ring: 3/16 Flat Top with 4 Valve Reliefs Pin Diameter: 0.927", Pin Length: 3.00" SOLD!! Pictures can be provided upon request. Please contact me through PM or email at tboucher1122@gmail.com for purchase of if there are any questions. Thanks
TJ Boucher Super Stock 1122, Stock 1140 Last edited by T. Boucher; 12-10-2013 at 12:47 PM. Reason: Item Sold |
