Old 11-14-2006, 05:01 PM   #1
Andrew Starr
Default Jerico 4-speed with Long vertigate shifter
Jerico Transmission For Sale complete with Long Vertigate shifter. Mag case with bushing updates at input bearing and both ends of cluster shaft. 18 tooth input, Super Duty 14 ball input bearing, Turbo 400 output.
Does not come with front bearing retainer
3.04 First 33/15 gear set
1.90 Second 29/21 gear set
1.44 Third 25/24 gear set
1 Forth 21/29 gear set
Spare Parts include:
1-Mag Case
1-Mag lower cover
1-Mag tail shaft housing
2- Output main shafts (Turbo 400 spline)
1-18 spline inout shaft
3-21/28 Main drive gear sets
1-21/27 Main drive gear set
2-33/15 first gears
5-15 tooth Cluster shafts
4-Cluster bearing shafts
1-29/21 Second Gear
2-24/25 Third gear sets
3-1st/2nd shift dog rings
2-3rd/4th shift dog rings
1-1st/2nd sliders
4-1st/2nd slider hubs
4-3rd/4th sliders
1-HD 13 ball input bearing
1- output bearing
1-set of shift levers, arms, and slide pins
2-reverse idlers
Numerous bearings, snap rings, spacers, etc....
Enough parts to build a second transmission with plenty of parts left over
Asking $3500
Please call or email and I will be glad to send pictures or answer any questions. Thanks,
Andrew Starr
215-643-4607 days or 215-646-6386 night
efi@hilborninjection.com
Andrew Starr is offline   Reply With Quote
