Liked 13 Times in 7 Posts
I have 4 cams for sale for a BB Chevy, 2 rollers, 2 solids.
Comp Cams Roller part # 11-718-9 "" New in the original box "" Super Comp/Gas grind easy on valve train parts 427 up to 500 c.i. 322AR10, @ .050 284* in., 294* ex, .720 in, .714 ex, 110 Ls $ 250.00 Comp Cam Roller part # 11-000-9 "" Used Cam and roller lifters was in a 468 c.i., Dyno time only "" 308-5/312-5R8, @ .050 270* in, 276* ex, 108* Ls $350.00 Howard's Cam solid part # 122331 "" New Cam "" 427 up to 500 c.i. 302/310, @ .050 265*in, 278* ex, .626 in, .643 ex, Ls 108* $ 100.00 UDHarold Brookshire (UltraDyne Cams) "" New Cam Custom Ground for a 454 up to 480 with quick ramp speeds for c.i. 10.5 to 11.5 compression ratio & edm solid lifters "" 284/294, @ .050 255* in, 263* ex, .626 in, .626 ex, Cam ground with 4* advanced will degree at 108*, Ls 110 $ 300.00 Cams listed above plus shipping. ""NEW"" TRW Pistons Forged L 2304 F .030, for SB Chevy 350 and Moly rings, cost over $ 370.00, sell for $300.00 454 BB Chevy cast crank std/std now, should clean up with a polish $ 100.00 Comp Cams Stainless rocker package for SB Chevy, 10 runs old. 12 - 1.8 ratio 7/16 stud, clearance for a 1.650 dia. spring, no off set 11 - 1.6 ratio 7/16 stud, no off set 3/8 stepped guide plates B & B 12 - 3/8 x 8.100 x .080 wall, Trends Race Moly push rods Jomar Pro - Model stud girdle with spare adjuster/bolts ARP 7/16 studs Package price $ 500.00 Engine related tools SB Chevy cam bearing tool $ 50.00 BB/SB cam bearing tool $ 100.00 Ring file kit sold by Powerhouse $65.00 ""NEW"" Richmond Pro Gear for a 9", 5:67 $ 225.00 Thanks for looking and the ad space, Call or e-mail for a faster reply, I will ship out if needed. Let me know if I can help Ron Miller 26134 Cheryl Drive Brownstown,Mi 48134 734-782-9333 before 9:00 pm Ron Miller 3287 GT/DA 92 Camaro |
