Old 11-13-2013, 08:59 PM   #1
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
Default 1988 Z28 Camaro with Title
Had fun with this car. Ran it as a stock suspension 10.5 car.
Chrome Molly:
Cage (funny car)
drive shaft
front K member
upper & lower arms
coil overs front & rear
Ford 9" 4:56 Pro Gear
Wheelie Bars & Parachute
BG 400 fuel system
MSD 72al ignition
Wilwood disc brakes front & rear
Motor:
638 Donovan Block
Dart Heads
Dart Intake
Single 1250 Dominator
Lunati ProMod Crank & rods
14.5 JE gas ported ceramic coated pistons
Full Jesel valvetrain
Transmission:
Dedenbear Glide straight cut gears 1.96 first gear
Coan Converter 9" 6600 stahl
Car is untubbed with $18,000 multi colored show winning paint. Car has been 7.80's on skinney tire (10.5) at 3200 lbs. with another motor and will hook in sand box. Car goes straight and true. Comes with 2 hoods (1 cowl and 1 with scoop) both match the car. Car will re-certify to 8.50 and a couple of kidney bars and it will certify to 7.50. 638 only has 5 motor passes on motor since built new, NOS never activated.
Car does have title, can be seen by appointment, can email photos.
Will sell the following ways:
Turnkey $44,500 OBO
Rolling (I pull motor and trans you get everything else) $18,500 OBO
Motor $24,000 OBO ($38,700 invested and have receipts) This would make a good T/S or T/D motor
Glide with Converter $5,000
CASH IS KING, Need to move this car too as new car is coming.
832-264-2478 or email Nick@hoffpro.com
