Liked 427 Times in 97 Posts
430 ci small block Chevrolet
Chevy/Olds rocket block, Dart/olds 18 degree heads, Callies crankshaft, Oliver rods, Comp cam, Jesel rockers, Dart intake, Dons custom carb 4500, Msd crab distributor, MSD crank trigger, Morso vacuam pump, Billet fabrication oil pan & valve covers, Melling oil pump, CSR water pump, comes with Coan torque converter turbo input spline, also comes with Hogan sheet metal tunnel ram set up for 2 carbs or a single raised top, Ran 8.77 @ 152.50 in 2550 lb car with cast dart intake. $11,000.00 (see Racingjunk Ad #755610) 358 ci 600 hp Manley aluminum rods, JE pistons, callies crank, comp cam, AFR heads, Jesel rockers, MSD crank trigger, MSD distributor, BG 750 carb, Aluminum oil pan, Billet fabrication valve covers, Fluid damper, ran 9.51 @ 139 in 2820 pound car. $5,500.00 (see Racingjunk Ad #755608) Call (508) 580 2576 |
