Old 10-28-2013, 07:59 PM   #1
jgillen91
Default BBC CFE big chief heads Sheetmetal Tunnel Ram fresh
4.840 bore spacing. Lightened melin block 438" bbc. merlin block 4.625 bore 3.250 stroke. Bryant crank, mgp alum rods, gas ported venolia pistons. Reactor flexplate, ati balancer. Moroso dry sump oiling system [pan, pump and tank].Moroso vacume pump. Electric water pump. 55mm cam, jesel keyway lifters,jesel belt drive and jesel front drive dist. CFE olds big chief 14* heads rolled to 10*. Titanium valves. flow over 500 on int. CFE sheetmetal ram Moroso sheetmetal valve covers. csr starter. Engine is fresh. Heads are off for inspection of buyer.
Engine is fresh. Fresh line hone, bearings, and rings, springs. Rods checked!
$8,000
Text or call James 317-752-7406 jgillen91@yahoo.com
Have more pics.
Located in indianapolis.
jgillen91 is offline   Reply With Quote
