Old 10-23-2013, 05:31 AM   #1
tafc10
Default Repairing Slicks
Hey guys,
Got a screw in the centre of one of the slicks, we currently run them tubeless and I was gonna just put a plug in it and good to go but.....
Any of you guys plugged a slick before?
Something I got no experience with.
Thanks
Geoff
tafc10 is offline   Reply With Quote
Old 10-23-2013, 07:55 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Repairing Slicks
I have never run tubes and been plugging slicks and front runners for over 2 decades without issue. The best plug kit by far is this one...
Old 10-23-2013, 08:15 AM   #3
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
I as well have plugged slicks in the past without any problems
Chuck
C and W Racing is offline   Reply With Quote
Old 10-23-2013, 08:47 AM   #4
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
I don't race a Super Comp or Super Gas car,but if I had this problem,I would be getting new slicks.I wouldn't take the chance,but that is just me.
Old 10-23-2013, 11:37 AM   #5
supergas4
Liked 6 Times in 5 Posts
I have mounted 100s of slicks.If you use the sticky plug it will work fine.I ran one on a s/g car for 10 races.
supergas4 is offline   Reply With Quote
Old 10-23-2013, 12:10 PM   #6
Joe Demarais
Joe Demarais's Avatar
Super glue works the best
Joe Demarais SS
Joe Demarais is offline   Reply With Quote
Old 10-23-2013, 01:07 PM   #7
Ghost Missle
Ghost Missle's Avatar
Liked 30 Times in 19 Posts
This is by no means a personal recommendation but at the Chevrolet-
Toyota dealership where I work we use a Tech brand repair system
wherebye the tire is dismounted, the inner carcass is prepped and
buffed and a large "mushroom" patch-plug is applied from the inside
along with a special sealant.
We have never had an issue with these as it is impossible for the patch
to come loose. Of course I would never plug a tire tread close to the sidewall.
Check dealers in your area.
http://www.techtirerepairs.com/
.............................The older I get....The faster I was
Ghost Missle is offline   Reply With Quote
Old 10-23-2013, 01:57 PM   #8
1320racer
1320racer's Avatar
The inner carcass of a passenger car tire and that of a slick are not the same. Try prepping/buffing the inner carcass of a slick and you are quickly into the cords with no rubber left to bond the patch to. Further, a passenger tire does not go out of round as a drag slick does on acceleration which would allow the patch to deform and likely lead to failure IF you were sucessfull getting the patch to bond to the carcass. Vulcanizing is the right fix but cost prohibitted if it could even be done to a slick.
Me, I'll continue to plug slicks and front runners at the track/in the lanes, when the need arises, in minutes, ensuring I don't miss a round.
Old 10-23-2013, 04:28 PM   #9
Ghost Missle
Point taken, The "tread" area of a slick is very thin. I thought a
"mushroom patch" from the inside would be safer but the patch
area on a slick would deform massively more than on a street tire.
Old 10-23-2013, 05:51 PM   #10
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Repairing Slicks
Geoff,
Put a plug in it & be done with it , have been doing it for years without a problem .. *Only works when leak is in bottom surface ,not on side-walls !!! Plugs also work very well on Trailer tires .... Go for it, buy a Kit and always be prepared ...
Dave Ribeiro 1033 STK
