Old 10-08-2013, 08:58 AM   #1
FLEMING
Liked 54 Times in 25 Posts
Default 355 with J/E dome pistons Brodix CNC track 1's
I am selling my bracket motor I just built, has about 30 runs on it.. GM .010 block .030 over with JE dome pistons crower roller cam and lifters, Scat rods and GM steel crank balanced rotating assembly, SFI Balancer and flywheel Mr. Gasket oil Pan, cloyes timing set, Brodix STS CNC track 1's (215'S).. Comp Gold rockers with stud girdle 7/16" studs hardened .080 pushrods .. Super Victor intake that has been Nitro plated ...
Motor is very stout for 355.. Has been running 6.90's @ 96 mph in my 3600lb 9" tire nova... Selling to build stock eliminator motor. When motor sells I also have BG belt driven fuel pump with bypass and APD alky carb as well
$4200
FLEMING is offline   Reply With Quote
