Old 12-08-2006, 09:02 AM   #1
been200mph
Default Glide built to handle BIG hp
New Glide built to handle massive power. Can be changed to shorty style, just ask. $3200 either way. Has:
1-pc SFI certified case w/Chevy bolt pattern
1.80 straight-cut gearset
ringless Vasco input shaft that still provides cooler circuit operation
race front pump with aftermarket killer strong stator support
10-clutch high gear with steel clutch hub
race band
dual-ring low servo
aftermarket band adjuster bolt/nut
250+ psi line pressure Pro-style hydraulic-release transbrake
coated deep cast aluminum pan
aftermarket roller tailhousing or shorty cover plate
If you look around you'll see why this is a great deal at $3200!
Shipping is normally around $100 to a business, and a little more to a home address.
Contact me nights 8pm-10pm at 319-233-5677, or 1pm-10pm on weekends, central time.
http://www.oldanimotorsports.20megsfree.com
Oldani Motorsports, dealer for TCI, JW, BTE, ATD/Hipster, Comp Cams, Jesel, Stef's/B&B, Jomar, etc....
been200mph is offline   Reply With Quote
