Old 08-21-2013, 04:59 PM   #1
482nova
Default Lots of questions bbc 71 Nova, 400 T,4.56 gear
482 bbc,ported oval ports,256/266-580/605 comp solid cam,10.3 comp,Q 850,ported RPM intake. Built by Paul Mercure 'years' ago,still runs great. R44T AC plugs? Jetting same as delivered new. 15 year old Coan 10 inch with 400 turbo, 'about' 3500/400 stall ? 4.56 12 bolt with Strange internals. Full Calvert bars,F/R shocks, split springs. Easy 5'' travel front. 29.5x9 ET drag. Correct plugs?, What is the most 'aggressive' Cal-Trac set up, Top hole? Rear shocks softest or stiff? How does one 'figure' stall speed? Is that converter 'hurting' me, new tech vs old? 15 lbs cold tire pressure, any less, car 'moves around' to much. Best 60' 1.49 'not good'. 3250 w/o driver. No brake. Going to hit the track soon, would like a list of 'to-do's. Motor makes 600/620 hp. 6400 rpm. I know I sound silly.
482nova is offline   Reply With Quote
