Old 07-31-2013, 08:29 PM   #1
rod
Liked 20 Times in 15 Posts
Default tire section width?
if you had one tire, with 10" tread and mounted it on a 10" rim, and then mounted the same tire on an 8" rim...would the section width be wider on the 8" rim than on the 10" rim?
thanks Rod in AZ
rod is offline   Reply With Quote
