Old 07-29-2013, 07:34 PM   #1
flash
Liked 6 Times in 5 Posts
Default open cockpit race car helmet
what are most super class racers using in the open cockpit super gas cars? getting air up under the front of helmet.using a neck collar-with a simpson bandit helmet. a lot of brands with a lip built into the front.just wanted a real racer opinion of what racers are using.
flash is offline   Reply With Quote
Old 07-29-2013, 07:58 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
Default Re: open cockpit race car helmet
I'd try putting a windshield with a slightly higher lip in the center in front of the driver ,before changing helmets.
My windscreen is 1 1/2" higher in front of me , about 7" wide ,than the rest of the screen.
Made a huge difference.
Old 07-29-2013, 09:56 PM   #3
pmrphil
Liked 348 Times in 152 Posts
You might try a different style (wedge?) collar that supports the helmet better also.
Phil Molski
PMR Performance
S/C 1623
Old 07-29-2013, 11:02 PM   #4
Tom Goldman
Should ask what body style you have .
'27-'37 bodies have the driver much more exposed to the air flow than Vette bodies.
I know I could feel a difference on my Vette just from changing scoop styles.
Old 07-30-2013, 08:25 AM   #5
flash
63 corvette,but I think it's the location-setback-and roundness of the hood scoop that is directing the air back toward the drivers compartment.
Old 07-30-2013, 09:22 AM   #6
Tom Goldman
Probably...The scoop sets very high on that body .
I'd try raising the windscreen a little.
a small increase in height or a small lip will make a big difference.
Old 08-04-2013, 09:54 PM   #7
Bill Baer
Actually getting air under the front of the helmet is not always a bad thing,when the weather cools off (usually at night) you may find you self with a fogged up visor or a fogged visor and eye glasses , in which case lifting your chin up and getting a little air under the helmet will usually clear it up.
After I bought a HANS I had to add a helmet skirt so now I get no air under the helmet and if the visor fogs,I have to try to crack open the visor slightly before staging to let a little air in.
P.S. if it's fogging bad, I wait till the last possible moment to put the visor down and hold my breath till the car is down track
Old 08-08-2013, 09:20 AM   #8
TS310C
I have a 63 Vette roadster and was having issues with the wind trying to lift my other helmet off my head. It was a short Simpson carbon helmet. I went to a Simpson speedway shark with a front wickerbill. That made all the difference in the world! Of course getting used to the wind also helps, but the other helmet would have never worked in this car. Just way to short. I currently use a neck collar, but as soon as I remember to order a head sock I will be using my Hans.
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
Old 08-13-2013, 12:59 PM   #9
sc371f
I have an Impact Draft. I got it because I was getting lift on my Simpson Super Bandit. It was unreal how big of a difference it made.
sc371f is offline   Reply With Quote
