Old 01-15-2007, 07:50 PM   #1
Brian Holcombe
Default 385" SBC, PUMP GAS engine, Street/strip 11.15@117
For Sale:
Street/strip Pump gas
4.040" 4 bolt 010 casting block 3.75? Stroke crank= 385ci
The block was prepped by Windsor Automotive Machine (Paul Rock)
- The block prep included being decked to 9.03"
- Line honed mains, Bores honed with a deck plate
-SRP Forged Pistons #138094 with Plasma Moly file fit rings
-9.85:1 CR Completely pump gas capable
-Clevite 77 bearings
-Fel-Pro Gaskets
-Eagle Cask Crank 3.75" Stroke External balanced by Performance machine
-Crower Sportsman 6? cap screw Rods
- All bolts internal and external are ARP, with exception to the rod bolts which are Crower.
-Milodon louvered Windage tray, and Milodon oil pan (Stock style)
-Melling Standard oil pump, Heavy casting design with pickup epoxied and staked.
-Cloyes true Roller timing set
-World Products Sportsman II 200cc intake port heads 72cc combustion chambers fitted with Race Flo 2.02/1.60 valves bowl blend
All the valves (brand new) were resurfaced, and back cut.
Head work included a bowl blend and 3-angle (3 seat angles and a back cut) competition style valve job
-Performer RPM intake manifold
-Crower Cams #00321 (Ground on a 108LSA) Solid Flat tappet 242/248 Dur .050? .482/.504" valve lift Crane double Valve Springs #99893-16
-Rocker Arms- Crower Stainless Steel 1.5
-Comp One Piece .080? wall 5/16? Pushrods
-Headers- 1-5/8? primary 3? collector, 33? average primary tube length
Scavenger style collector
-Steel damper
This engine has 96 1/4 mile passes on it, and less then 3000 street miles.
It has gone 11.15 at 117.5 MPH in a 3210lbs 67' Camaro.
Comes complete, less distributor, waterpump, alternator and carb. (carb is negotiable).
$4,800
Interested in Stacks of Paper ONLY, no trades.
Hear it run prior to purchase.
[image]http://i27.photobucket.com/albums/c181/SpeedyGoomba/P1010035.jpg[/image]
Brian Holcombe is offline   Reply With Quote
