Old 06-12-2013, 05:47 AM   #1
GTX JOHN
Default Brand New 440 Stocker Engine
Brand New 440 Stock Eliminator Engine
with ALL the Enhancements and Best of Everything!
Don Little Cylinder Heads/Manifold approximately 193 CC Intake
port well under NHRA Specs with the latest Enhancements
West Coast Style that flow as good as anybody's. Custom Cam and Springs
also from Don.
Tri City Engineering built Shortblock with CP Pistons and Luneauk Rings
properly prepared/machined by a top Stock/SS Builder.
HEMI pan and pickup 7 Qt. Cap. with right baffles and work!
Rocker Arm Engineering Ratio Rockers and Smith Ceramic
lifters modified properly by Little.
New MSD Distributor and SFI Dampener.
New CSI Electric Water Pump.
Currently set up as legal '73 to '74 Head CC and Deck.
With approx 83.3 CCs. Could be cut to any 67 to 71 Specs Easily
(79CC) with plenty Piston to Valve.
Deck could also be cut to any earlier combos 27 or 52 and/or
thinner head gaskets to adapt it to 67 to 71 specs. although
it would be comfortably legal without changing anything and still well under
(Just giving away some compression til you freshen it next time around).
It also includes four Correct workingThermoquads including one
very fast and expensive one by a top shop1
Also Legal 67-69 Manifold plus a 70 and a 71 Manifold and
correct legal Carbs for each combo.
Two Inch Hooker Headers ncluded.
New $1800 Step Coated headers in Box available for extra
$ 350.00 instead only with Engine purchase.
$14,000.00 Plus Invested stil in Crate.................First $4,750. Takes It
and your ready to go racing and will not be disappointed. That is Well
Less than either the heads and rockers cost or the short Block and has
gotta be worth every penny!
At this price you could use it in your bracket Car!
Also: Low Compression '72/'73 340 engine with about 60 Runs that is
still in my Demon and complete Carb to Pan. Don Little Heads/Manifold again
and Tri City Shortblock. It has been 1.06 under in my G/SA car and won many heads up races.
In the Heat this time of year in Vegas it will go 70 -85 in Bracket Mode. It is fast enough to
run SS/JA or SS/KA and run index in fair to decent Air in although it is legal
stocker! This year (April 2013) got to last 3 Cars in Superstock and last 7 cars last year
at (April 2012) Vegas Nationals when my son broke his Superstocker and borrowed although
he had never driven it before and Altitude showed 5500 Ft and big headwind!
$6,750.00
Add my just freshened Pro Trans Straight Cut Transmission and Best Dynamic Custom Converter out
of my car for Add'l $ 3,950.00 only with engine and I am sure it would duplicate a similar
performance in you well prepared body and you would be very competive with anyone!
Racer7411@yahoo.com
