Old 06-07-2013, 10:17 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default 1974 Duster 383 BB/727/4:56
1974 Duster, recent Vitamin C paint job, 8 point S&W roll bar with swing out
bars, welded in frame connectors, MP BB K-member, Ceramic coated Hooker
Super Comp fenderwell headers and 3" SS exhaust to rear bumper.
All trim and emblems nice, chrome bumpers decent. Autometer tach, guages,
Taylor switch panel MSD-6 box. Black interior, factory buckets 5 point harness.
1970 383 motor 0.030 over 10 to 1 flat top pistons, 906 iron heads, MP 557 solid
cam and MP iron adj rocker assy. Steel crank. 727 trans with 10" convertor,
reverse pattern valve body with Turbo Action shifter, 12 gallon fuel cell.
Factory front disc brakes, 8-3/4 rear end W/10" drums, welded brace on housing
4:56 Sure-grip Weld Wheels 3-1/2X15 and 8-1/2X15 new 275/60/15 rear tires.
THE GOOD: The 906 heads just redone by Shane Studley (Precision Cylinder Heads).
Heads are off the motor.
THE BAD: Short block needs rings, low compression in #1 cylinder.
Short block still in car.
I can email pictures.
$7900 OBO
EXTRA's--- 73-76 V8 spool K-frame, chrome deep trans pan & 2 cases of trans
fluid, extra electric fuel pump, new line lock + install kit, extra set of Sumitt Weld
style 8X15 rims, extra pumpkin W/3:91.
PM here or email to Phil at saran_motorsports@yahoo dot com
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
