Old 01-24-2007, 12:11 PM   #1
Brian Holcombe
Default 450HP pump gas SBC - LAST PRICE REDUCTION
This is it, it ethier sells or i hang onto it for a future project, if anyone is waiting for me to give up and give it away, keep waiting cause it aint gonna happen :wink:
Complete 385 Stroker Engine
What is included:
450HP 385cid Chevrolet small block
Flowtech headers with custom collectors
Meziere 55gpm street/strip electric water pump
Internal Specifications:
Block: Seasoned 4-bolt GM 010 Casting (2pc rear)
Crank: 3.75" Eagle Cast Steel crank
Rods: 6.0" Forged crower sportsman
Pistons: 4.040" SRP forged 1/16" Ring design
Gaskets & Bearings: Clevite & FelPro
Cylinder heads: 200cc Sportsman II iron heads
Intake:Edelbrock RPM
Camshaft: Crower solid flat tapped 242/248 duration
Oil System: Milodon pan, P/U, and Melling Pump
Timing Chain: Cloyes True Roller
Valve Covers: Moroso with moroso breathers
Valve train: Crower stainless Roller rockers & Comp heavy wall Pushrods
Balancer: Pro.Series External balance
Flexplate: External balance SFI
Machine work and assembly performed by Windsor Automotive machine.
This engine is nearly brand new, and was built entirely with brand new parts (Except the block), after a handful of drag strip passes, and 3000 street miles its being replaced by a big block.
Take advantage of an excellent deal which includes the Headers exact combo (Capped with exhaust!) has gone 11.15 @ 117.
Hear the engine run prior to purchase, and i will remove the engine at the time of purchase.
NOT INCLUDED:
Alternator and bracket, crank pulley, Distributor, Starter, carb, carb spacers.
$3,450
Interested in Stacks of Paper ONLY, no trades.
[image]http://i27.photobucket.com/albums/c181/SpeedyGoomba/P1010035.jpg[/image]
I have No problem giving all the required info for the buyer to get the right carb/converter.....however the current ones will not/cannot be included in the deal.
Patrick James (pro systems) are excellent guys to deal with and they will duplicate the carb, and i will unveil all my tuning information.
ATI can duplicate the same converter, since i will supply the serial number if so requested.
Brian Holcombe is offline   Reply With Quote
