Old 05-25-2013, 09:41 AM   #1
SmBlkFord
Default HP & Density Altitude ?
Trying to figure a couple things out. Will a higher HP motor be affected more by weather changes ? always thought less but it takes more HP to go 8`s then it would 9`s,Can anyone verify ?
SmBlkFord is offline   Reply With Quote
Old 05-25-2013, 11:34 AM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: HP & Density Altitude ?
I believe that it is a percentage correction. Therefore higher HP will lose/gain more from changes in DA.
Dan
voltdr is offline   Reply With Quote
Old 05-30-2013, 03:26 PM   #3
Rollins_2241
It will lose more HP, but because it takes more HP to lower ET as you get faster, high HP will be slightly more consistent ET-wise for the same change in weather conditions. Yet another reason to take a second mortgage to go Super-class racing.
Rollins_2241 is offline   Reply With Quote
