Old 05-13-2013, 06:21 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default 2001 Chevy 1500HD engine question
My truck when idling has a stumble. It will run smooth then rough then smooth back and forth. Didn't do it while driving before. Now when pulling at low speeds it started doing it. When at highway speed even pulling its fine. Check engine recently came on but it's for the knock sensor. I was told that wouldn't cause the stumbling? No other codes when checked. Ideas? Thanks.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-16-2013, 12:46 PM   #2
tj310
Default Re: 2001 Chevy 1500HD engine question
Water in the fuel ? ---Trevor
Old 05-21-2013, 04:24 PM   #3
offroadr
How old is the fuel filter?
offroadr is offline   Reply With Quote
Old 05-21-2013, 07:09 PM   #4
Ed Carpenter
So far new fuel pump, new filter, wires, plugs, pcv valve. No change. Bought new intake gaskets and knock sensor. Doing that next.
Ed Carpenter
Old 05-28-2013, 03:10 PM   #5
John Kissel
Liked 230 Times in 94 Posts
Did you try the following, clean the mass air flow sensor, clean the throttle body, check the intake manifold gaskets, is there any oily residue in the intake manifold from the crankcase vent. system, and do you use any type of injector cleaner. I use the Lucas fuel treatment with excellent results in my '95 F-150 (195k), '99 5.7 Suburban (115k), BUT Chevron Techron has worked miracles in my wife's '06 TrailBlazer SS (135k) that has had similar problems to yours.Believe me, I know full well how frustrating this stuff is. Carbs. and distributors forever!!
John Kissel is offline   Reply With Quote
Old 05-31-2013, 06:46 AM   #6
Ed Wright
Ed Wright's Avatar
Ed, remind me next time we are both going to be at the track. I will bring my Tech2 scan tool. I should be able to tell you what it is, and which cylinder(s) are the culprits. The knock sensors won't be the problem.
Ed Wright 4156 SS/JA
Old 05-31-2013, 08:30 PM   #7
Ed Carpenter
Ok I will Ed thanks.
Ed Carpenter
Old 06-04-2013, 01:23 PM   #8
4speedracer
Liked 10 Times in 6 Posts
You will need harness for knock sensors also, water bad to get trapped in knock sensor holes. Jamie
4speedracer is offline   Reply With Quote
Old 06-30-2013, 11:09 AM   #9
jscamaro1
Liked 3 Times in 1 Post
Ever check the Idle air control? That little actuator deal is always moving back and forth to maintain your idle characteristic maybe try a new IAC.
jscamaro1 is offline   Reply With Quote
