Old 02-02-2007, 11:10 AM   #1
fast81
Default SBC 406 with 041x heads
This is a complete motor, still in the car, and you can see it run.
It is being sold complete from intake to oil pan and from flexplate to pulleys.
Specs:
400 sbc bored .030
GM 041x heads--bowl blended with arp head bolts
511 casting 2 bolt block
stock crank
stock rods with arp rod bolts
TRW L2352 forged pistons
10:1 compression--pump gas
Comp Cams 292H hydraulic cam
244/244 501 lift
lobe seperation 110
2500-6500 rpm range
(Used all comp cams cam kit)
edelbrock rpm intake
Holley 130 mechanical fuel pump
As stated above, it is from intake to oil pan.
Includes sfi flexplate, balancer, and waterpump.
Includes March underdrive pulleys.
All you will need to add is a carb and a distributor.
It even includes a set of dynomax headers for a 70-81 camaro.
It includes an extra stock crank, set of stock rods, and two sets of gm 882 heads.
One set of the 882 heads is bowl blended with 2.02/1.60 stainless valves.
$1500 for all
It will stay in the car and be running for everyone who may be interested to see.
email me at
tnt.racing@charter.net
fast81@charter.net
cell #864-303-5646 or 864-304-2608
We are located in Gaffney, SC.
fast81 is offline   Reply With Quote
