Old 04-30-2013, 09:58 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-72 SBC & BBC Hi Performance Parts
1967 3919840 square port heads rebuilt E-18-7 & E-23-7 $2500
1968 3919840 square port heads H-23-7 & I-18-7 stock $1250
1968 3919840 square port heads both dated D-23-8 stock $1250
1968 3919840 square port singles A-12-8, C-18-8, F-18-8 stock $600 each
1969 3919840 square port heads both dated B-20-9 stock $1250
1969 3919840 square port heads I-17-8 & I-30-8 stock $1250
1969 3919840 square port singles J-29-8, G-31-8, C-27-9, D-30-9 stock $600 each
1968 396-375HP 4 bolt standard bore block #3916323 I-2-7 $1750
1969 396-375HP 4 bolt 30 over rebuilt shortblock #3955272 H-9-8 $2500
1969 427-435HP 4 bolt 60 over block #3935439 F-14-8 $2500 all machine work done
1969 427-335HP 2 bolt standard bore block #3963512 K-11-8 $1500
1970 454-450HP 4 bolt 60 over block #3963512 L-9-9 $2000
1970 454-365HP 2 bolt 30 over block #3963512 J-21-9 $1500
1972 427-430HP 4 bolt standard bore block #3999289 $2000 stamped T1202LO
1966 3885069 aluminum intake 12-2-65 $300
1968 3885069 aluminum intake 11-20-67 $300
1971 3994026 square port heads both dated I-9-71 stock $1250
1968 3919842 single stock aluminum square port head 12-13-67 $1750
6223 steel cranks $300 each
7/16 rods non dimple $100
7416 steel cranks $300 each
1969 350-300HP motor complete intake to pan #3956618 dated A-4-9 with 186's $900
1969 3931063 oval port heads both dated K-7-9 stock $500
Chrome factory dripper valve covers $100
330-770-2517 Dennis for any questions and can ship if you cannot pick up.
dlv4540 is offline   Reply With Quote
