Old 02-06-2007, 08:14 PM   #1
JKenny
Default 565 12-Degree Pro-Filer
565 BBC/12-degree Profiler Spreadport Heads, 4.600 Bore x 4.25 stroke, Freshened & Dyno?d @ D&D Performance, 1095 HP / Dyno sheet available, Dart Big M Block tall deck (10.2) w/billet caps, .903 lifter bores w/ bronze bushings, ARP main & head studs, Crower lightweight Crank, Crower steel rods, 6.700, JE Custom pistons / 14.5:1, Total Seal Rings, F-M Main & Rod Bearings, Dart Special coated cam bearings, NEW Reher-Morrison / Erson 7-4 swap roller cam, Jesel Belt Drive, Jesel pushrods, Jesel offset shaft rockers, NEW Crane Offset lifters/ .903 dia, Profiler 12o Hitman Cylinder Heads, Cometic MLS head gaskets, Manley Titanium Valves, NEW Manley Nextek Valve springs, Manley Titanium retainers with bead loc locks, Profiler Spreadport Tunnel Ram intake manifold - set up for single dominator or Ron?s Terminator, Moroso Billet Oil Pump, Moroso 2 piece Wet Sump Oil pan #20376, Fluidampr Harmonic Balancer, MSD front drive Distributor, MSD Crank Trigger
New Cost over $26,000, Sell for $18,500, Contact: alkenny177k@hotmail.com
JKenny is offline   Reply With Quote
Old 02-07-2007, 09:49 PM   #2
Mackie Family Racing
Default
Jason,
how's the weather up in God's country? did the old man get a speeding ticket yet in that little yellow car??
is the motor you've got for sale the same as in my dragster, or is it like your dad's?
say hi to all. Was in Vegas over the weekend, got out to the track twice to watch the testing. Hilary Will and Federlin had some pretty huge wrecks...
Scott and Lucy
BaBaLoo Racing
T/D 3189
SG, SC, SST 1808
Mackie Family Racing is offline   Reply With Quote
