Old 04-22-2013, 07:21 PM   #1
Notch1320
Default 87 - 93 Mustang, SBF Stocker Motor
311ci SBF Intake To Pan (87 - 93 Mustang)
.060 J&E Pistons With Coated Skirts (#141602)
.013 Offset Ground Crank
ATI Super Dampner
ATI Timing Pointer
Eagle Rods
Coated Bearings
Ishiharra-Johnson Teflon Crank Scrapper
Canton Stock Eliminator Oil Pan
Melling Oil Pump
ARP Oil Pump Drive
Factory Distributor
ARP Bolts On Everything
Double Roller Timing Set
Custom Low Tension Rings From Greg Luneac & Chris Hardy @ RET
Bullet Billet Cam
Smith Brothers .080 Wall Pushrods
Roller Rockers From Alex @ Moneymaker Racing
Cliff Sherman Lifters
Manley Valves
Comp 999 Springs With Inner Removed
(RET) Chris Hardy Prepped E7 Heads http://www.racingenginetechnologies.com/
This combo has been 11.79 @ 111 in K/S trim.
Has less than 50 passes since built.
I will separate the Heads and Short Block as well.
Engine was Assembled By Daves Engine Machine
37530 Enterprise Court Newark, CA 94560
(510) 797-9536 (Angie & Dave)
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
