Old 04-21-2013, 10:30 PM   #1
Michael Kilduff
Default Gooseneck or 5th wheel for a 2/3 car trailer?
Hey gang,
I've only towed single car tag style car trailers before and am looking to buy a 2 or 3 car open aluminum trailer. I'm curious as to what is preferred and why-gooseneck or 5th wheel? Looks like the 5th wheel is easier to back into for hook up, but maybe I'm wrong about that?
Tow vehicle is a crew cab '98 Chevy dually, will have a new or slightly used Dodge or GM dually in the next year.
Give me the good, the bad, and the otherwise on the gooseneck or fifth wheel if ya can. Thanks in advance
IHRA STK 932 O/SA
Michael Kilduff is offline   Reply With Quote
Old 04-22-2013, 11:36 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Gooseneck or 5th wheel for a 2/3 car trailer?
As for the amount of room that is used in the bed of your truck. I have a hide away ball for my gooseneck. I can remove the ball and flip it over and have full use of the entire bed of the truck. I am not sure what the 5th wheel hitches offer, but this is the hitch that several experienced racers suggested to me. It is not that big of a deal to hook the truck and trailer together with the gooseneck. Just find a center point on the truck and that is what you are shooting for to get it lined up, to connect.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-22-2013, 01:22 PM   #3
bobby
bobby's Avatar
Most 2-3 car trailers are going to be gooseneck. Most 5th wheels are found on travel trailers. I would get a hidden hitch. 5th wheels are heavy and cumbersome to move if you ever need to use the bed to haul bigger stuff around.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 04-22-2013, 02:25 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,202 Times in 977 Posts
Advantage of the fifth wheel arrangement is a easier ride by offering a "soft" attachment to the truck. Either way I'd recommend a B&W hidden hitch which they offer a "companion" hitch for if you decide to go fifth wheel (which are common on big toy haulers and such). I have a B&W companion for sale btw.
B&W is a great company...google them.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-22-2013, 09:35 PM   #5
G Anderson
Liked 4 Times in 3 Posts
The Goose Neck is MUCH harder to hook up than the bumper !
But you wont hardly know the GN is back there,follows you real well no pull-push from passing semi's!
The GN is also quite a bit heavier,so takes a bigger horse-towed my 34' Haulmark with 98 3/4ton 350 vortec 1st year bought 2003 3/4 ton Dodge Cummins after that--previous trailer 24' Haulmark bumper The hitch for my GN is called Drop n Locks,I like it real well
G Anderson is offline   Reply With Quote
