Old 04-10-2013, 01:14 AM   #1
ss wannabee
Liked 7 Times in 7 Posts
Default Delco ABS-VI brake questions....
Changing a master cyl on a '98 Lumina sedan...Couldn't borrow a scan tool...
To simplify bleeding, BPMV modulator valves should be in "home" position...
Factory manual on one page says ..to turn modulator gears COUNTER-CLOCKWISE
to achieve "home" position....
On another page...it says to turn gears CLOCKWISE....
One is a mis-print or....?
Going to bleed manually....understand start with forward bleeder valve on BPMV...then do I do the rear valve on BPMV...or leave it alone now? Maybe later?
Next I think you do RF wheel...then LF...and then drive car 5 mph...or a little more?
Finish up with RR...and then LR wheel? Do I have that right?
Don't think traditional RR-LR-RF-LF sequence applies here?
Boy, do I miss the one-lung m/c days!
ss wannabee is offline   Reply With Quote
