Old 04-07-2013, 12:47 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default 273 TRW Legal Piston
Does anyone have access to older NHRA piston list for 273 4BBL replacement piston. Came across a set of old TRW's and would like to use for a new stocker build. Thanks
Last edited by House of Darts; 04-07-2013 at 12:49 PM. Reason: Forgot some extra info
House of Darts is offline   Reply With Quote
Old 04-07-2013, 07:30 PM   #2
older racer
Liked 68 Times in 26 Posts
Default Re: 273 TRW Legal Piston
hi, I found trw numbers for 235/273 ,L2222nf. I couldn't find sealed power numbers.hope this helps
older racer is offline   Reply With Quote
Old 04-08-2013, 08:48 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
NHRA does not remove listings for approved pistons. That's so that people using older aftermarket pistons that are no longer manufactured can continue to use them. If your pistons are not on the list, then you will have to go throught the process to get them apporved.
