Old 04-03-2013, 09:14 PM   #1
SST5523
Default sb mopar loses oil pressure prime overnite
my sb mopar loses its oil pressure prime overnite but once started for the day its ok
any suggestions would be helpful thx
SST5523 is offline   Reply With Quote
Old 04-04-2013, 03:25 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: sb mopar loses oil pressure prime overnite
Does the oil filter that you are using have a anti drain back valve?
How do you know it's losing its prime?
How is the filter mounted?
2009 V/SA Record Holder
Old 04-05-2013, 07:45 PM   #3
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Is it possible the oil pump is not tight against the main cap? I have seen some pumps hit the stud or bolt and leak oil between the pump and main cap.
Patric Fox is offline   Reply With Quote
