Old 04-03-2013, 10:47 AM   #1
sportsfan
Default Cutting fiberglass
I need to make some changes to a fiberglass hood.But I'm not sure what tool to use to cut it.I thought about using a Dremel with a reinforced cut off wheel.Any suggestions or advice?
sportsfan is offline   Reply With Quote
Old 04-03-2013, 11:22 AM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: Cutting fiberglass
A rotary cutoff wheel (Dremel), a reciprocating saw or hand saw works. Make sure your in a well ventilated area (outside?) and suit up (cover all exposed skin) wear a mask ,if you can do it on a cool day it helps minimize the itchiness of the fiberglass. Mark your area and make rough cuts and then fine tune with hand sand paper or file.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-03-2013, 12:56 PM   #3
Kegracing
X2 on Dion's suggestions.
Also, I have covered cut lines with duct tape, both top and bottom before. Helped keep edge cleaner... Just peel off toward the cut, when done. Little less dust also.
Good luck
Ken
Kegracing is offline   Reply With Quote
Old 04-06-2013, 10:55 PM   #4
sportsfan
Smile Re: Cutting fiberglass
Thank you for the advice.I worked up the nerve to make the cuts and it worked great.
Old 04-06-2013, 11:21 PM   #5
hookdaddy
Liked 8 Times in 3 Posts
The rotary cutoff wheel will leave a nicer edge
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
