Old 04-03-2013, 10:47 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Holley spread bore carb.
Are these carb.'s any good for a performance motor a friend has about 7 of them and i was thinking about buying them.I have a cleveland iron intake i wanted to put one on.
astikhossw is offline   Reply With Quote
Old 04-03-2013, 01:18 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Holley spread bore carb.
Why wouldn't they be? It's a Holley so all Holley tuning tricks & parts apply. The rear metering plate can be replaced with a metering block, the vacuum secondary springs can be changed, jets can be changed, cams, etc., all in the name of tuning for performance or mileage.
Jeff Lee 7494 D/S '70 AMX
Old 04-03-2013, 06:15 PM   #3
jims5600
Liked 21 Times in 9 Posts
Jeff is spot on,take his advise
jims5600 is offline   Reply With Quote
Old 04-03-2013, 07:11 PM   #4
Jeff Lee
Jeff Lee's Avatar
I'm not sure the Holley spread bore is a direct bolt-on for a 351C factory Autolite 4bbl intake. I think it needs an adapter. Been a while since I've messed with 351's....
Old 04-04-2013, 03:13 AM   #5
bad440
bad440's Avatar
thinking 73s were spreadbore intakes...
bad440 is offline   Reply With Quote
Old 04-04-2013, 03:30 AM   #6
Jeff Lee
Jeff Lee's Avatar
I know the 1973 and newer Autolite is a spreadbore but I'm pretty sure the bolt pattern for the four studs is something weird. But there are adaptors available.
Old 04-04-2013, 06:20 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Jeff is correct. The Autolite spread-bore pattern is different than Q-jet, Thermoquad, and Holley layout. There used to be adapters available, so maybe you can find one.
Old 04-04-2013, 08:33 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Spread bores work good,sometimes they take more tuning than regular holley,secondary can be hard to get smooth,vac. secondaries are harder to tune than mechanical secondaries spread bores came both ways
Mike Taylor 3601
Old 04-04-2013, 01:34 PM   #9
Carguy49
Liked 2,967 Times in 713 Posts
I have used several of these carbs in the past (20 years ago). They are very tunable and when setup properly can give reasonable fuel mileage on the street. Since they use small primaries and larger secondaries tuning can be somewhat tricky. Shouldn't be a problem for anyone who has spent time tuning a carb for a certain combination. Good luck and should be a very doable project. I have a question, does Holley still build spreadbore carbs??
Ron McDowell - Did Race
Old 04-04-2013, 10:06 PM   #10
astikhossw
astikhossw's Avatar
Thanks guys i just had a performance carb. guy with his own shop tell me that the spread bore holley was junk.And with the rarity of the cleveland aluminum intake not available to often and with the old spread bore iron intakes cheap and plentiful its good to have another choice in a stocker build.
