Old 03-25-2013, 01:30 PM   #1
FGaspare
Default 60's Chevy Engines For Sale
I have stored these engines for 40 yrs. # on rear of block 3892657. front of block FO7IIEC, 462 heads, double hump. second engine # on rear of block 3970010, front pad VO623HN, 3927186 heads, double hump. I think the first one is a 66 327, the other is a 69 350. If any one has info please tell me, I know there is alot of knowledge on this site, much more than I have. Thank You, Frank 419-433-4101 call anytime till 7:00 p.m. EST.
FGaspare is offline   Reply With Quote
Old 03-25-2013, 07:57 PM   #2
joelster
Default Re: 60's Chevy Engines For Sale
The first one is either a '65 or '66 327 out of a Chevelle, with a 4bbl. Either a "special high performance" 300hp version or a 275hp A.I.R./powerglide. It was built on July 11th at Flint.
The second one has 4 possible combos, from a '65 327 fuelie Vette, to a 69 350/300hp in a full size. It was built on June 23rd at Flint
You can look them up right here:
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
There should be a vin number also on the same pad. That will tell you the year of the engine.
joelster is offline   Reply With Quote
