Old 03-19-2013, 09:07 PM   #1
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Default Can I use sand bags for ballast?
I know it's not legal at a divisonal or national event but my car is 400 lbs heavier on the front than the back and its not hooking up. I also am the worlds worst at setting up a suspension. Can I throw some sandbags in the trunk spare tire well? I know it won't be ridgidly mounted, but will it serve the same purpose? Thanks for your help.
rickseeman is offline   Reply With Quote
Old 03-19-2013, 09:22 PM   #2
69ss/rs
Default Re: Can I use sand bags for ballast?
No, whatever ballast you use must be secured in a weight box or bolted to the car. Just check in the rule book and it will tell you what will go and what won't.
69ss/rs is offline   Reply With Quote
Old 03-19-2013, 09:30 PM   #3
Troy Pourciau
If the sandbag will fit in your weight box, You can use it. But like 69ss/rs said it must be secured.
Troy "City Dog" Pourciau
Old 03-19-2013, 10:44 PM   #4
Steve Williams
I don't what type of vehicle you have, but I know that I ran into an issue of where to put weight and what to use on a V-8 S-10 (iron head SBC). Got a piece of 4"X3" and a piece of 4"X2" steel bar stock (164lbs, 109 lbs) cut to length, drilled it on each end and attached to the rear frame rail behind shock mount with nylock nuts and grade 8 bolts. Could bolt in one, the other or both if I wanted to. If you are 400 lbs nose heavy, it may be better to go a little further back. I mounted from one frame rail to the other. Provided you make good steam, traction problems may give way to putting it on the bumper. Sand bags sound like trouble to me.
Steve Williams is offline   Reply With Quote
Old 03-19-2013, 10:52 PM   #5
James L Miller
Liked 25 Times in 16 Posts
I had four 50# sandbags in the back of my 1989 Shelby Dakota when I slid off I-20 near Longview when the road iced over. I was doing about 60 MPH when I left the road. They put a big dent in the front of the bed. You probably don't want that hitting the back of your seat or helmet if you crash with loose ballast. Being that you might be doing twice what I was doing, one bag at 120 will be like all four at 60 MPH. The old, KE=1/2mV^2.
Mopar 2 Ya!
Old 03-21-2013, 06:37 PM   #6
lstanford
Liked 134 Times in 32 Posts
No, but they will work real good if there is a flood at the track.
lstanford is offline   Reply With Quote
Old 03-21-2013, 10:48 PM   #7
Kegracing
This probably fits better in the "things you got bounced for" post, but I never got bounced for it. Was a bracket car, 15+ years ago too...
Had a 68 Nova with small tires. Hot NC summers and slick tracks, and I had two 50 lb bags of quickcrete in the trunk. Laid them back against the bumper inside the trunk, and after a couple of weeks, they were hard and molded to the shape of the floor and rear panel. Ran them for a couple of years, before someone said something about them, and I finally took them out.
Looking back at some of the things I did when younger and dumber... and smiling!
Ken
Kegracing is offline   Reply With Quote
