Old 03-13-2013, 04:20 PM   #1
Lynn A McCarty
Lynn A McCarty's Avatar
Default Aftermarket blocks in SSers
Well, until now we have run stock Pontiac blocks. After about 10 years of pursuit NHRA finally allowed us to use the aftermarket block a couple of years ago. I just ordered mine. We have extensive dyno work with the 455SD and the stock blocks.
I remember a huge discussion(mostly denial) about how aftermarket blocks make power. Yes if you do everything the same, it probably makes the same power. Yes, I still have to run the cast iron heads. I cant cut the deck much due to the 4.210 stroke and 6.625 rod.
Anyone want to make a guess on how much power this is worth? We are going to find out for sure.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 03-13-2013, 05:57 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Aftermarket blocks in SSers
25-35 HP for a Pontiac, all else being equal in preparation.
Jeff Lee 7494 D/S '70 AMX
Old 03-13-2013, 09:37 PM   #3
Hudlow66
Hudlow66's Avatar
That's probably a good number, Jeff. Im always a little on the conservitive side when it comes to HP numbers. From a stock Pontiac block to the aftermarket blocks (Im guessing it's either the IA from Butler or the MR-1 Kauffman), you should gane a ton of stability in the cylinders. Let alone the solid valley...!
Phil Hudlow 6678 (S/C, S/G, ET-PRO)
Hudlow66 is offline   Reply With Quote
Old 03-14-2013, 02:38 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
What if any is the difference in weight?
2009 V/SA Record Holder
Old 03-14-2013, 02:12 PM   #5
Lynn A McCarty
Dont know exactly, but I have been told like 70lbs heavier. Since there is more meat in the sleeves then we dont have to fill the blocks or install the braces on the lifter bores. I fill the entire area with epoxy after installing the brace to keep the block from moving around. I will see how much more net weight. Pontiac 455s benefit with weight on the front anyways to keep the wheels down.
