Old 03-05-2013, 10:52 PM   #1
Brad Plourd
Liked 67 Times in 20 Posts
Default 1974 Vega S/Gas, S/Street, S/Pro, Pro, or ?
Hi, race fans, here is a really nice 1974 Chevy Vega with a 468 BBC and a 1.76 low gear Powerglide with a TCI #6282 Pro Brake valve body. Transmission has zero runs and a A-1 5500 8”stall converter. She is a .730" roller cam open chamber aluminum head 4 bolt main motor with a single 1050 Holley Dominator. The engine was assembled at Keller Motorsports with JE 14-1 pistons, Manley valves, Eagle "big H-beam rods" and has run as quick as 8.83 on spray (included), 9.40's at 143 without. So, pick a class and get after it! The chassis was built at Performance Fabrication and is a 4 link coil over 4 wheel disc car. Twin batteries, nice fuel cell and aluminum work as you can see from the pic's. The paint was just done in July, base coat/clear coat. It looks similar to a famous 70's Pro Stock car. It is chrome moly round tube with a funny car cage certified to 7.50. The electronics include a Biondo Mega digital timer, MSD dist and 7aL2 with 2 step. Auto shifter of course. She is a light weight car @ 2300#'s with a 12 bolt Chev rear housing 4.88 Richmond gears and 35 spline axles. This car drives as nice as they can. New 14x32 tires (25 runs) Belts, chassis are current. This car raced at the season opener Winternationals in Pomona. Went 3 rnds . Go Racing Now !!! Call Bernie @
425.890.0921 bwplourd@hotmail.com
$16,900 or rolling.....let's talk !!
Brad Plourd is offline   Reply With Quote
Old 03-08-2013, 10:25 PM   #2
tallison55
Default Re: 1974 Vega S/Gas, S/Street, S/Pro, Pro, or ?
Brad, do you have any pics or where can I look up Pic s?
Thanks Terry
tallison55 is offline   Reply With Quote
Old 03-09-2013, 02:48 PM   #3
tony wood
Liked 42 Times in 17 Posts
Terry if he went 4 rds. at Pomona go to autoimagery Brad Plourd.
tony wood is offline   Reply With Quote
Old 03-09-2013, 04:07 PM   #4
1299
Liked 54 Times in 12 Posts
the pic of the vega are under Bernie Plourd on autoimagery
1299 is offline   Reply With Quote
Old 03-10-2013, 01:30 PM   #5
Brad Plourd
Hi, this is Brad's Dad, Bernie. I would be glad to send pictures or go to racingjunk, there is an ad there. Type in 1974 Vega, or get me your e-mail and I will send some.
