Old 03-04-2013, 09:14 PM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Shop clean out !
New factory GM oil filter adapter with bolts(not Plugged) $20
New factory long starter bolts $5pr
Moroso Lightweight BBC fuel pump rod $10
Moroso BBC valve cover hold downs (set)) $10
Q-jet to square bore intake adapter(with hardware) $10
BBC Crower Roller lifters Very low runs (#66291H-16) $300
Comp BBC Roller Lifter #897-16 (New In Box) $300
Mallory # 28880 Coil $75
MSD RPM Chips 8,83 & 9000 rpm $25
MSD 6AL box to dist cable (NEW) $10
BBC Victor Head Gaskets $50 pr
Q-Jet Billet Spacer( Faith Air) $150
Richmond 9inch gear (5.29) $200
Tranny Sheild TH-350 $75
Merge Collectors -22 inch long 2 1/8 primary pipe 3 to 4 inch merge $200
Merge collectors-19 inch long 2 1/8 primary pipe 3 1/2 to 3 ¾ $200
Dynomax Race Bullet Header Mufflers 2 1/8 primary pipe $200
JAZZ clear Fuel Jug $20
Moroso solid core BBC wires. (Sleeved and heat shrinked ) $125
ATI Suoer F tranny fluid $75 case
Joe Gibbs XP1 5w/20 oil $200 case
Old 03-05-2013, 03:45 PM   #2
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
Default Re: Shop clean out !
PM sent. :-)
Steve Obertanec
Steve OB is offline   Reply With Quote
