Old 03-03-2013, 11:30 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-72 BBC & SBC Parts
1966 11 inch 396 & 427 flywheel #3789733 dated K-24-5 $100
1966 #3885069 aluminum square port intake 12-2-65 $300
1968 #3885069 aluminum square port intake 11-20-67 $300
1967 3904391 square port heads C-14-7 & C-15-7 $3000
1967 3904391 square port single head K-22-6 $1250
1967 3919840 square port heads rebuilt E-18-7 & E-23-7 $2500
1968-69 3919840 square port heads singles and sets
1969-70 3964291 square port single head rebuilt dated F-6-9 $750
1971 3994026 square port heads both dated I-9-71 $1250
1968 396 4 bolt standard bore block dated I-2-7 $1750
1969 396 4 bolt rebuilt shortblock dated H-9-8 $2500
1969-70 427 & 454 blocks #3963512 2 & 4 bolt
1972 427 warranty replacement block casting 3999289 stamped T1202LO for a 1969 427-430HP motor
1969 427-435HP block #3935439 dated F-14-8 stamped T1011LX 19S70738 fresh 60 over all machine work done with two sleeves $2500
6223 steel cranks $300
7416 steel cranks $300
7115 steel crank L88 & ZL1 $1000
8 inch factory harmonic balancer #3870325 $150
#964 4 bolt caps $100 per set (3)
Chrome dripper factory valve covers $100 per set (2)
BBC crower camshaft 290 duration 585 lift $50
427 11 to 1 pistons mounted on 7/16 dimple rods balanced to a 6223 steel crank $700
BBC oil pan $100
1969 350-300HP 2 bolt motor complete from intake to pan w? #186 heads $900
Can ship if you cannot pick up and can send pictures with an email address. Any questions I can be reached at 330-770-2517. Almost all of the parts listed have been cleaned and magged. If not and you want it done I can get it taken care of. All parts guaranteed to be good.
dlv4540 is offline   Reply With Quote
