Old 03-01-2013, 11:09 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 798 Times in 212 Posts
Default Ford F350 Reviews Anybody ??
Are these trucks mechanically sound ??
Anybody own one of these for towing ??
Are they Good or Bad Vechicles ??
Looking at the 2003 Diesel.
Thanks
"Pistol" Pete Dutko
Old 03-01-2013, 11:18 PM   #2
gonzo1066
Default Re: Ford F350 Reviews Anybody ??
I could NOT reccomend the 6.0 diesel in the FORD. Seems a few run well and quite a few have issues that are expensive to repair.
gonzo1066 is offline   Reply With Quote
Old 03-02-2013, 12:13 AM   #3
FED 387
Liked 333 Times in 180 Posts
Absolutely do not buy a 6.0 or a 6.4 diesel nothing but problems do not buy a 2003/2004 to 2008 with a 6.0 engine---- many recalls/blown head gaskets--MAJOR ENGINE proplems--bad injectors etc---only a 7.3 or the new 6.7 but never a 6.0---rest of the truck is OK-- look online see the horror stories!!!!
Old 03-02-2013, 01:06 AM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
I am guessing since you are asking for opinions you dont work on diesels for a living. If I could not work on them I would pass. Not worth the risk. Too many expensive problems with them.
Old 03-02-2013, 05:30 AM   #5
Pistol Pete
Thanks Guys...
"Pistol" Pete Dutko
Old 03-03-2013, 02:41 AM   #6
gonzo1066
IF you can find a earlier FORD with the 7.3 diesel they are a good engine, although these trucks bring a premium price. The Dodge Cummins 03-early 07s have been really good rigs, although the auto trans will need attention if the truck has towed trailer most of its life. I assume that you are going to tow your race trailer and car? This should be light duty unless you have a LQ trailer and lots of storage area.
Old 03-03-2013, 11:23 AM   #7
Pistol Pete
Default Re: Ford F350 Reviews Anybody ??( FED 387 )
Mr FED Are you talking just about the Ford's 6.0 ????
Or GM models too.....
Thanks
"Pistol" Pete Dutko
Old 03-03-2013, 11:32 PM   #8
FED 387
FORD 6.0/6.4 Power stroke diesel engine--
Old 03-03-2013, 11:45 PM   #9
FED 387
bought mine new---I have a 2000 Ford with the 7.3/ auto trans---238,000miles--- Replaced ball joints at 56,000 no grease fittings in the OEM's---replaced 3 out of 4 calipers pins froze up in them assorted mileages but between 75,000 and 150,000 miles--water pump at 98,000 just froze up would not turn---turbocharger at 126,000 impeller disintegrated--- both batteries after 8 years time for new ones one was going bad so did both at the same time ----tires at 130,000 BF Goodrich 235/85/16R E load range --change oil/ oil filter/air filter every 7-8000 miles only use Shell Rotella 15-40W summer and 15-30W winter--gets about 17+ unloaded and 12.5 towing--- KEEP IT UNDER 1800 RPM FOR BEST MILEAGE get up around 2000 RPM +++ and just sit back and watch the fuel gauge move to E
Old 03-05-2013, 12:12 PM   #10
69Cobra
Liked 2 Times in 2 Posts
I looked for 8 months flew half way across the country to find a nice 7.3 with low miles. Mine is an '02 and when I bought it, it had 114k on the clock and now it might have 145k three years later but I've been over here in the 'stan for 2 years. My Dad has a 99 and this is the truck that sold me. Dad's is a two wheel drive crew cap dually and its just a nice truck that's all there is to it. The biggest problem with the 7.3 is the cam sensor. Mine went out about 6 months after I bought it. I called my Dad on the phone told him that my truck wouldn't start so he went to the KOI and got a cam sensor and brought me a 3/8 drive ratchet and 10mm socket. I had it changed out in 5 minutes and we were back on the road. I keep one in the glove box just in case. Other than that I change the oil, oil filter, fuel filter every 5K miles and its the best truck I've owned. Mine is a single wheel crew cab 4 wheel drive and I love it. Other than the passenger door where some dumba$$ backed into the side of it.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
