Old 02-28-2013, 09:21 PM   #1
keith ohanesian
Default 85 f/sa- i/sa camaro $11,500 obo
85 Fuel injected Camaro for sale. This car can run from F to I. It has no problem meeting the G minimum at 3005 pounds with a 190 pound driver and with meet middle of F.
12 bolt rear with Strange axels and spool.
5.13 Richmond pro gears
Fresh and updated ATI convertor
Fresh Seppanick 200 metric with last years updates.
Hurst pistol grip shifter
Aluminum fuel cell mounted in the trunk with an Aeromotive pump.
Magnaflow fuel regulator
Holley Commander 950 fuel and spark management system.
Headman torque step headers with a third step added along with Performance Welding merge megaphone collectors. All are non coated.
Lakewood front struts and Comp rears.
Custom free floating torque arm and one Lakewood lift bar.
Wiring was redone recently
All brake lines are done with AN tubing nuts.
Underneath completely stripped again and painted.
JFZ front brakes drums on the rear.
6 point bar
American racing track stars on the front and weld pro stars on the back.
This car is set up to run fuel injected or carb.
Some misc spares go with it.
Will come with the tpi manifold and injectors
Add your motor and race. This car can run with 5 different combos.
$11,500 rolling obo
This car can be sold anyway
$9500.00 car only
$1200.00 trans
$500.00 convertor
Thank you Class Racer!
No prep is king
keith ohanesian is offline   Reply With Quote
