Old 02-26-2013, 10:16 AM   #1
Lyn Smith
Liked 983 Times in 198 Posts
Smile P glide to to 3 speed switch.How much is it worth???
Well what does it look like the p glide to 3 speed swap is worth ?Looks like a few of the p glide races have picked up some with the swap.
Old 02-26-2013, 10:21 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: P glide to to 3 speed switch.How much is it worth???
On my combo .08-.10 depending on track and weather, 3000# 650 horse.
Joe Buchanan SS/BX 3117
Old 02-26-2013, 11:31 AM   #3
Don Kennedy
Liked 902 Times in 237 Posts
FYI
Last weekend my car shifted from first to third it slowed the car down appx 16 figuring in the weather . I went a 9:28 with the 1st to 3rd shift then a run that shifted normal i went a 9:17 with the weather 500 feet higher . The shift messed up first round when i had a perfect light but would not run the number beccause of the problem of not ****ing right Hopefully I got this problem solved will test on wednesday
Don Kennedy 7701 SS
Old 02-26-2013, 12:25 PM   #4
philbilly
philbilly's Avatar
As soon as I get my car pulling all the way thru the 1320 I am gonna test the 3 speed vs. the powerglide. I will make three runs with glide then switch to a turbo on same day with same converter.
philbilly is offline   Reply With Quote
Old 02-26-2013, 12:38 PM   #5
jaf2021
Liked 5 Times in 5 Posts
I have always read that a 3 speed will help a heavier car(3200# up) more than one with lesser weight. Example 66 chevelle 3400# vs 91 calais 2900#. Any input please
Thanks jason
jaf2021 is offline   Reply With Quote
Old 02-26-2013, 02:02 PM   #6
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
stocker at 530hp - 1968 Camao F/CM weight (3005).
best of 10.44, average fast runs at 10.48-50 with the glide
best of 10.53 average fast runs 58-61 with the 3 speed
the 3 speed had quicker 60fts. 1.32-35 vs. 1.37-38
the glide had better 330's on through to the end
i believe it was becasue the 3sp had the front end higher and the car was bouncing upon coming down. i have tried Caltracs front shocks and their new harder retract shocks. i have installed new Santauff front shocks to try this season and will be coming out with the 3 speed to see if we can stop the rears from hazing during the bounce (i do have to steer when the car comes down with the 3sp.)
2 speed was always 2-3 mph quicker to the quarter.
3 speed is ALWAYS more fun!
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 02-26-2013, 03:35 PM   #7
RON TAYLOR
Originally Posted by lyn smith View Post
well what does it look like the p glide to 3 speed swap is worth ?looks like a few of the p glide races have picked up some with the swap.
the ride is worth the 6000.00 RON TAYLOR
RON TAYLOR is offline   Reply With Quote
Old 02-26-2013, 09:19 PM   #8
james schaechter
Liked 1,436 Times in 299 Posts
Lynn, I think you need a trick high gear only set up with that torquebeast you have!
James Schaechter 3163 STK
Old 02-26-2013, 10:36 PM   #9
Todd Hoven
Guest
Posts: n/a
What kind of 3 speed were you running? Unfortunately if you dont have a Pro Trans or a very good Metric you will see no performance gain in any T350 or 400 compaired to a PG. Its just the way it is. Those transmissions have to many rolling parts and carry to much weight. The glide stock is much lighter than those 2 trans. If your not prepaired to spend 3500 and up for a good metric or 5K and up for a pro trans just stick with the glide.
Better yet, install a man lever and pedal and have alot more fun..
Old 02-26-2013, 10:46 PM   #10
Jeff Lee
Jeff Lee's Avatar
So is it allowable in NHRA to run a PG when the particular engine and body was a 3-speed auto?
Jeff Lee 7494 D/S '70 AMX
