Old 02-26-2013, 09:24 AM   #1
michel426
Default 1964 dodge 330... B/sa
1964 DODGE 330 B/SA...
.4 wheels Wildwood disc brakes
.8-3/4 spool and lightweight Strange axles, braced
.10 points Roll Bars
.Welded body seams
.Cal-Trac style rear suspension
.QA1 front shocks-double adjustable
.QA1 Ball Joints
.QA1 Strut Rods
.Fuel cell w/aeromotive A2000 fuel system
.16 volt Powermaster
.Weld Magnum wheels
.M/T front tires - Hoosier's rears
.Turbo Action Shifter
.Racepak Sportman Data Logger
.V DO gauges
.Painless switch console w/harnesses
. Car is clean and good looking...
.TRANSMISSION:
.727 w/all aluminum lightweight
.A&A drums
.Griner valve body
.RCI Blanket
. ATI 6000 converter Treemaster
Motor:
.426 Max Wedge .070 over
.Scat crank 3.763 stroke
.Manley rods
. cp .070 legal pistons
.Akerly rings
.Mopar Perf. Max Wedde Heads
.Man ley valves
.Isky springs
.Comp roller
.Comp Cam w/Schubeck lifters
.Max Wedge repro intake
.Carter HP carbs
.MSD dist,wire,7al-3 box
.Hooker headers
.MEZIERE pump and electric fan
.FLUIDAMPR, Indy, ETC.....
.FRESH MOTOR, TRANSMISSION AND SUSPENSION...
.CAR READY TO RACE...
. (TURNKEY) $45,000.00
.(ROLLING W/OUT MOTOR/TRANSMISSION) $25,000.00
.Michel Cote
.450-378-6993
.450-775-7540
magnum.autosports@hotmail.com
see pictures at :
http://www.pbase.com/nahima/max_wedge
michel426 is offline   Reply With Quote
Old 03-02-2013, 12:06 PM   #2
426Fred
Liked 2 Times in 2 Posts
Default Re: 1964 dodge 330... B/sa
Sent you a PM
Fred Palumbo
1025 STK
426Fred is offline   Reply With Quote
