Liked 427 Times in 97 Posts
2006 250” Dan Page "Hard-tail" Top Dragster
23” cage w/Carbon fiber seat 1900 lbs w/ nitrous system and 200 lb driver Consistant 6.70’s @ 200 mph w/ 632 ci engine & 250 shot of nitrous, top 10 qualifier, easy to drive in any conditions, lots of testing data available with this car! Weld Wheels w/ bead lock rims, New Turbo-Start 16-volt battery Aluminum battery cable, MSD 3AL ignition Racepak 300 w/Racepak Dash currently w/10 channels, K&R cube delay box Moroso E.S.P. Wiring & Switch panel, Moroso water recovery & breather tank Custom Moroso belly pan (no diaper used) Fragola plumbing, FK rod ends, Quarter-Pro electric shifter Taylor Motorsports 7 point harness w/ Taylor motorsports dual chutes Ron Davis radiator and fan, Wet & Dry-sump front motor plates Mark Williams bolt thru center section w/4:30 Richmond pro gear Lamb brakes and rotors Art Gallant Carbon fiber wing w/ streamlined struts Single wheel adjustable wheelie bar Entire car built with "Specialty Fasteners" Wired for nitrous – Ready to "Go Fast" with the touch of a switch Lots of "Custom" and Innovatative touches on this car Car is race ready! Add your engine and transmission and go! Nothing has been stripped or removed, set up to qualify easily for any Top Dragster race in the country! $14,500, FOB picked-up at Moroso Performance in Guilford Connecticut E-mail: scotth@moroso.com SOLD! Last edited by Greg Barsamian; 06-28-2013 at 04:00 PM. |
