Old 02-17-2013, 02:32 PM   #1
fordteacherguy
Liked 160 Times in 51 Posts
Default Low Drag Wheel Bearing Lube?
To All:
I'm out here doing my winter/spring maintenance on my stocker/SS and just as any stocker racer does, I look at any place I can reduce drag.
I've used thin WB grease for years, but there are certainly less drag alternatives for lubing your front wheel bearings. I've heard of lubing front bearing with everything from just plain ole engine oil, trans fluid, gear lube...... or switching to ball bearings, or even the high buck ceramics.
What do you guys have luck lubing your ole regular tapered front bearings with? Don't want to burn up a bearing , but WB grease sure drags more than I like!
Thanks!
fordteacherguy is offline   Reply With Quote
Old 02-17-2013, 02:48 PM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Low Drag Wheel Bearing Lube?
sent u a PM
Old 02-17-2013, 03:02 PM   #3
tj310
Default Re: Low Drag Wheel Bearing Lube?
I use snowmobile grease . I have used wheel brg. grease for planes in the artic.---Trevor
Old 02-17-2013, 07:44 PM   #4
SSDiv6
Liked 1,600 Times in 583 Posts
Lamb Racing Components
