Old 02-16-2013, 01:56 PM   #1
Larry Fulton
Larry Fulton's Avatar
Default Carter - WCFB...
Does anybody know what the Application &/or Part Number is of the Largest Venturi Bore WCFB models?
Any input is appreciated.
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 02-16-2013, 08:08 PM   #2
Default Re: Carter - WCFB...
I'd bet Dean Oliver should know.
http://www.deanoscarbs.com/
Old 02-16-2013, 09:04 PM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Carter - WCFB...
For what it's worth, about 37 years ago, I had a red '65 Impala SS convertible, 327 with a 4 speed. It had a WCFB. I saw that it was a bit larger than the 265-283 carbs of the late fifties. That's probably both the last application of that carb, since '66 Chevy 327's had a Q jet or an AFB or a Holley, and the largest CFM rating. If that's what you need, you might try looking for one off of a 348.
Old 02-17-2013, 01:16 PM   #4
Larry Fulton
Found the info I was after on my own...
Thanks
Larry Fulton
Old 02-17-2013, 01:59 PM   #5
Tom Meyer
Liked 354 Times in 120 Posts
Should be able to look in the blueprint guide to find most of them. Tom
Tom Meyer 5240 SS Stock ???
