Old 02-14-2013, 09:07 PM   #1
nb2841
Default Back shocks
I have a 1967 nova with a 327, it has always had a floater suspension. I am taking it to the chassis shop tomorrow to put double adj Alfco under it. It weighs 3200 with me in it. What lbs springs should I run in the back? It's a 14x32 tire car. Thanks in advance.
nb2841 is offline   Reply With Quote
Old 02-14-2013, 10:02 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Back shocks
Assuming the shocks are behind the rear and you have an approximate axle weight of 1450# or about 45% , I'd start with a 130# spring.
I always prefer to use a lighter spring and have to load the spring to attain the proper shock center distance.
Old 02-14-2013, 10:08 PM   #3
nb2841
yes the shocks will be placed in behind the rear 9" housing. And they are 12" shocks.
Old 02-15-2013, 07:10 AM   #4
SCOTT TILLEY
I have a '65 ChevyII I run in Super Stock Production with IHRA. It weighs 3030 with me in it. I use a 110 spring. Shocks are behind the rearend. I used a 95# spring for years. I thought maybe the shocks were bottoming out after talking with several racers on what spring I should be using. Turns out that I had no on track performance gain with the 110 spring. Same 60 foot of a 1.31-1.33 with a 327 2 bbl. I did notice the rear was much stiffer with the 110 riding through the pits.
Scott Tilley
IHRA SS/PDAII
SCOTT TILLEY is offline   Reply With Quote
Old 02-15-2013, 08:12 AM   #5
curtis reed
Liked 125 Times in 59 Posts
Here is a nice little spring rate guide from Afco. I would have the chassis shop scale the car if you haven't so you would know the actual weight on the rear.
http://static.speedwaymotors.com/ima...rts/AFCOIL.gif
curtis reed is offline   Reply With Quote
Old 02-17-2013, 09:42 AM   #6
Liked 10,793 Times in 2,244 Posts
Thanks Curtis, very good info.
